A few people have now mentioned intergas......what makes these boilers so good?
Solid build quality with only 4 moving parts (2 if you have the heat only). No secondary heat exchanger, no diverter valve, no air pressure switch, no complicated hydro block, and no plastic or rubber - all waterways are copper, surrounded by an innovative injection-moulded aluminium heat exchanger which was originally designed over 25 years ago. Some examples of that original design are still in service today and doing very well. Look at your supposedly "premium" brands and how much plastic and rubber is now used, in the drive to make them lighter weight and cheaper to make.
Intergas are compatible with the most energy-saving OpenTherm controls, which work using two-way communication to achieve best efficiency for your boiler. Again, the "premium" makes don't do this - they insist you buy their own ultra-expensive BUS controls to achieve the same level of energy efficiency, at a cost of hundreds of pounds. An OpenTherm control for a combi can be had for as little as £55.
Compact design which sits just 240mm off the wall, saving you space over others which can be as much as 370mm deep.
Is parts availability an issue? With a 10 year warranty, not at the moment, and there are stockists around the UK who can supply parts if required.
It's my boiler of choice, and 95% of my installs are Intergas. I genuinely don't think there's anything better out there
