Hello folks. Not sure if I've got a problem or not! I've spent weeks updating my heating system in my 2 storey house. Changed the Potterton Kingfisher floor standing boiler for a Glowworm 18 hxi condensing wall mounted boiler, topped up by an f & e tank in the loft. Split the heating into 2 zones, so now there are three zones including domestic hot water, each with a gate valve for balancing. Added TRVs and programmable stats. Finished the pipework on Sundayand am now flushing out the flux etc, prior to finally filling and treating with Sentinel. My question is - the 15 mm feed to the system gets warm/hot, is this ok? The water in the f & e tank gets quite hot too. It seems wasteful of energy and less than ideal as warm water encourages bacteria to grow. The feed is run from the roofspace to the floor of the airing cupboard and then rises 1200mm to fill the system (I thought this arrangement would stop heat getting into the feed pipe). The sequence of connections on the flow side is boiler, 22mm vent, then 70mm to 15mm fill, pump (Grundfoss Alpha+), bypass valve, motorised valves. It occurs to me that the only expansion that actually goes into the so-called expansion pipe (probably better called a vent pipe) is the same few inches that the water level rises in the f & e tank. The rest has to into the feed pipe, so perhaps the way to deal with this is to make the volume of the upward rising part of the feed pipe large enough to contain all the expanded water. That would put the bottom of the loop in the cellar if I had one! Perhaps a better solution would be a vessel installed in the feed pipe line large enough to take the expansion, but i don't know if such a thing is made.
l've got another question, if you can bear it. I change the hot water cylinder to an Albion CF80 quick recovery cylinder some years ago. It has a pocketed thermostat, which I dont think is faulty. If I set this higher than about 30C, the hot water is so hot it is almost dangerous. If I set it a smidge lower, then I get little or no hot water. I think the problem is that the thermostat pocket is actually below the level of the indirect coil, so doesn't pick up the water temperature properly. Maybe i should put a strap-on thermostat on in the usual position? Seems a shame to lose the precision of a pocketed thermosta, though.
My apologies for the length of this enquiry, but I should be eternally grateful fo answers.
Ricarbo (because they say I eat too much carbo- well so does Pavarotti)
