Please can some body tell me if i need to upgrade 16mm meter tails to 25mm meter tails when using a Henley to install seperate cu for 8.5kw shower.
ta.
Hopefully nobody will, because the lack of knowledge that question indicates, both of electrical design fundamentals and the realities of the job, means that you are bound to have other gaping holes in your knowledge and a lack of appreciation of the dangers involved.
Please get an electrician. Any other course would be madness, and any advice to the contrary would be highly irresponsible.
