yes, in 22mmYou did run a seperate cold feed directly from the tank to the pump?
Does the ballvalve keep the water level fairly level when the shower running ?
If it dosn`t it may be not enough head of water to supply the pump when the level drops
The cylinder is constantly topped up from the tank in the loft so no air will get in...only cold water (ready to be heated)
i did monitor the water level in the header tank as the pump was running and it stayed almost full the whole time
