Are you certain you have it connected correctly ?
Balenza said:You also need a minimum distance of 600mm between the bottom of the CSC and the top of the pump.
And the water temperature must not exceed 60c where pumps are fitted above the hot outlet from the cylinder.
nabby68 said:i have a worcester 2.8i combi boiler. i recently bled my rads and now i need to re- pressurize the boiler, but i cant seem to find the filling loop on it for the mains water connection. the boiler was already installed when i moved in so, got no way of finding out from the installer. i have looked everywhere around the boiler but no sign of a valve or anything1
any ideas??
well, the latter is true, but shhh, dont tell that nasty tax man!And you seem to have a variety of boilers in your house or many different houses
Remove all speedfit fittings - they are often far too restrictive especially in pipe layouts such as this. I can't remember whether you can use metal inserts and compression fittings with this pipe. If not rip the lot out and use another make or copper for a proper job.
Finaly as Balenza suggests fit the no stop Essex since this is very free flowing.
thanks chris r for your help, do you know how i may rectify this problem?What may be happening is that the resistance to flow of the water going down into the HWC from the CW cistern is more than enough to lower the water level in the vent pipe to the point where air starts to get into the cylinder, and through the flange, to the pump. It takes a few minutes to do it, typically. As a purely temporary measure, if you put eg a speedfit cap on the vent pipe you'll be able to prove it. Under no circumstances leave it there.
ChrisR said:Of course I do - see if it's doing it first though!
G'night.
I don't understand the process you're using, which, seemingly, is to ignore some expert advice and canvass for more.
