On my wall there is a plug socket, which is good as I want to power my new wall mounted electric fire. What I want to do though is hide the power supply. I should note that there is a bit of a gap behind the skirt board which I have to play with.
My plan was to disconnect the wiring to the plug socket, and instead use a terminal block which I would tuck behind skirt board. Use a length of electrical cable running from the terminal block up to a terminal block behind the fire then use the terminal block to connect electrical cable to fire electrics.
Idea to use the 'additional electrical cable' is because it will be sunk in to the wall and plastered & papered over - and would rather lose this cable in case of any future electrical issue with the source or the fire than have to rip cable out messing plaster and wallpaper.
Does this seem reasonable? Looking for confirmation or other suggestions from those with more experiences than me.
Thanks in advance,
James
Thanks in advance,
James
