ban - all - sheds, rash assumptions on your part, an electrician will be checking and testing the entire setup.
Then why aren't you asking him these questions?
This forum is for advice is it not?
Yes.
My advice is to have an electrician do all of the design work, all of the materials specification, all of the installation work except trench-digging etc, as agreed up front with him, and as supervised and directed by him, and all of the testing.
That way you'll get an installation which is safe, complies with the regulations, and has an EIC.
OR - spend a lot more time learning things before deciding to tackle design work yourself. The thing is, installing new CUs, outside supplies, submains etc is not a trivial job, and I can assure you that it involves knowing far more than you think it does.
Asking questions here can be a useful part of a learning process, but they are not a substitute for proper structured studying. The key term there is "learning
process" - you cannot learn all the things you need to know just by asking questions here. It isn't structured enough - it won't provide you with a way to progress where each step builds on what you learned before.
You can't carry out a job of this magnitude by asking whatever random questions happen to occur to you. You've already shown that you have some dodgy misconceptions - what if you get something wrong because you have no idea your knowledge is wrong? What if you miss something because you simply have no idea it even exists, and just don't realise you don't know it?
What happens when the electrican turns up to checking and test the entire setup and tells you that you've made mistakes?
