Now there's an interesting oneWhy are you doing design work when you don't know what the Wiring Regulations say about ring final circuits?For future proofing I'll wire this up as a ring however keep the 16A RCB in for the moment
That would not be acceptable if you had any lighting - for which the maximum permissible voltage drop would be 3% (6.9V). However...Required Cable Size 2.5 mm
Voltage Drop 10.8 Volts.
Percentage Drop 4.7%
Are you saying that, having presented the figures for 2.5mm² cable, you intend to use 6mm² (which would probably be OK for lighting)?Required With that in mind, I can use a 6mm cable to give some further margin for error ....
It's a little hard to tell.Am I now on the right track?
That's obviously better, and the calculator seems to suggest (haven't checked it myself) that 4mm² cable would be adequate - so, if that's correct, 6mm² certainly should be OK.sorry John, a little unclear on my part. Using calculator on TLC direct site. If I change to lighting circuit on drop down and 3% drop, then I get the following:
Required Cable Size 4 mm
Voltage Drop 6.82 Volts.
Percentage Drop 3.0%
Current Load 23.9 Amps
Max Cable Load* 30.0 Amps
So if I use 6mm, a 30A fuse protects the cable run sufficiently. Then can use RCD +RCB or RCBO's accordingly.
There's a reason why nobody has mentioned that.One thing no-one seems to have mentioned is that this work is notifiable
ac505
Thanked: 0 times
You cannot export a TN-C-S supply.
You will need to isolate the armouring at the shed end, and fit a plastic CU with RCD main switch, and earth electrode.
