That was just another option I was considering if I was going to do it that way I would of left the circuit breaker as it is, It seems both ideas are allowed regardless, However it makes more sense to me just to run one feed to the attic, so I have stuck to the original idea. As I have said I don't need 32 amps and its the only thing that is stopping me. I have just finished running the cable from the spur to the attic socket position its not connected yet obviously just in place, I will connect it as soon as the new hager 20 amp circuit breaker arrives.Even if the anticipated loads are low, it seems a bit of a pity to me to down-rate a 32A ring circuit to 20A just so that one can have more than one socket on an 'unfused spur'. Personally, I would either extend the ring, as described, or else (per previous post) convert the spur to a fused one, leaving the rest of the ring as 32A.
