I think I can say the same thing.During my entire, long working life, I never, ever came across any joints, done by electricians, using solder, apart from large solder lugs, before the compression lugs came out.
I the only one I recall, was one I did under the kitchen units in my daughters house, I assume it was the kitchen fitters left the open ring and the only way I could get to the cut but live cable was full stretch laying on my belly and doing the job by feel. Initially I attempted crimps but didn't have the access for the tool.
Sadly it's a very normal thing to find including where the wires have pulled from the choc bloc. As mentioned earlier it's something I've done a number of times for a temporary supply (which John seems to suggest it's not what the discussions about temporary were)I repeat - I would be extremely wary of making any type of joint, in a normal run of trunking, filled with lots of other cables.
Indeed It would effectively be nothing more than a bespoke adaptable box and a method I've employed on a number of ocassions and not only for joints; this is 6 switches on 100x100mm, sorry about the terrible quality.I don't have an issue with the OP's short bit of trunking, if it's purpose was one of containing lots of joints.
