Last few weeks this FS120 has been a pig to start.
I put on the choke, a few pumps of the fuel bubble & pull it over. Once it tries to start I turn off the choke & start to pull again. After a couple of pulls it’s starts & all fine. This is how I have always done it.
This didn’t work last few times so now I’ve started to look for the answer.
I took the carb off & cleaned it out with carb cleaner. Carb is 1 year old as replaces it myself.
All seemed fine so tried my starting process.
I also fitted a new plug & air filter ambush for the sake of it.
So today I’ve started to pull it over but I see petrol in the floor so assumed I’ve flooded it, not because of my starting method but because on an issue I think ?
With cover & air filter removed I pump the bubble once & see fuel coming out of carb & into floor. It comes out the direction of where the air filter would be. Do we this tell you anything ?
I remove plug & looks dry.
Refit plug & pull it over again & it starts.
I can rev it fine so I leave it to warm up a little.
After say a minute it stalls.
Now I’m expecting it to start no problem seeing it’s been running fine but I can pull it over say 3 times & nothing.
Does this sound like spark or fuel issue.
Can’t see a spark in this daylight but once it starts & runs I assume that side of it must be ok.
