Hello:
Sorry to bother everyone again
I asked a question a while ago about how to deal with air getting into my heating system. The solution recommended here and by others was to convert it to a pressurised system. This I have now done - BUT still the problem persists.
System details:
Potterton Suprima wall-mounted boiler (just over a year old). Fully-pumped hot water and heating. 5 radiators: one just over a year old, a couple maybe 6 years old and a couple more perhaps 20 years old. Pump and main pipes to/from boiler renewed at the same time as the boiler.
Expansion vessel and filling loop feeding into the system approx 1.5 metres from boiler (I think on the flow side). Two auto air vents, one just after the pump on the output side, the other just after the boiler on the flow side.
Symptoms:
System can be pressurised up to any (sensible) level and when left idle will hold the pressure permanently. When running it appears to behave normally, the pressure increases a little as it heats up, then returns to the original level on cooling down. HOWEVER, the problem is that after a couple of weeks a significant amount of air can be found in the radiators (taking say 20 seconds to vent). Where it accumulates depends on which radiators are turned on the most; a small amount also accumulates at the vent point above the boiler. After venting the system pressure has dropped, and requires extra water adding to bring the pressure back up.
There are no signs of any leaks anywhere in the system. It is a first floor flat with mainly wooden floors and the person below is sure they are not being flooded.
Have taken advice from two plumbers so far, one of whom insisted there definitely must be a leak somewhere in the system, the other took some floorboards up to examine the only hidden pipes and concluded there was definitely no leak anywhere.
The only pipes which cannot be examined are a couple which are buried in a concrete floor in the bathroom area. But there is no sign of any leakage where they emerge from the concrete.
This problem is driving me to despair and beyond.
Anyone here with a magic wand to wave at it...?
Thanks in advance.
Simon Ashford.
System details:
Symptoms:
Thanks in advance.
Simon Ashford.
