Eeerrr, I thought a bypass valve was needed with an S plan cos if both valves shut as a result of a fault, it'll stop the boiler blowing up if it keeps tryin to work . If I don't have to fit one of these things GREAT , have I got the wrong end of the stick?
Yes you lovely Kev!. of course I will be told..................but you need to tell me EXACTLY how to set the thing, a tap with a spring ain't that helpful
Close the bypass fully.
Turn the boiler on at minimum rate with the normal flow blocked.
Open the bypass little by little, whilst I hold the pipe just after the valve.
When I feel the pipe getting warm, I open it one more turn.
