haven't read the last two pages of posts cos i am now pis@@d so forgive me if it has allready been covoured but the boiler won't try to work if the valves micro switches are interlinked with the boilerEeerrr, I thought a bypass valve was needed with an S plan cos if both valves shut as a result of a fault, it'll stop the boiler blowing up if it keeps tryin to work . If I don't have to fit one of these things GREAT , have I got the wrong end of the stick?
Interesting, I did not notice the similarity; what lead you to the conclusion?Diyedboy and coldberk, same person yous are being set up
Good effort.Ten pints 4 double vodkas and a hand shandy around back of club .
What is this mysterious research, and why does it fly in the face of common sense?Lads, this valve lark is causing me some consternation, so I've done a bit of research on the internet. It seems the ABV is needed when a CH system is fitted with TRV's in order to maintain flow through the boiler when the TRV's shut down.
An Incorporated Engineer with IGEM & Registered with the Engineering Council UK said:
