Turbo charger works off exhaust gas which is built up to a certain pressure (psi/bar) then a wastegate opens and spins the turbo at speeds of up- to 150,000rps sucking more air into the engine.
thats not how a turbocharged engine works at all.
you've got all the right components, care to rearrange them into a working scenario?
Thats not ALL the components but a few which i mentioned.
ok, i suppose i should of looked closer at what i was writing, to correct my terminology, wastegates are actually held shut until a desired or preset pressure is reached then gate progressively opens to allow axhaust gas to bypass the turbine. I wanted to keep things simple you see and not go into too much detail. Also just to add that turbines can reach speeds of 150k, and i did use UPTO as not all will but the max rpm for the new vw turbo charger is 220k just for example, and you know i meant rpm.
i used psi/bar because its the most common and if you want can measure in Kpa, which correct me if im wrong 100 kpa=1bar/14.7PSI, but i prefer PSI.
hope that clarifies things for the post and gives you something to read while you on your tea break
