hi, couple of questions i have regarding a PIR our firm had done if anyone would be so kind,
1, the Inspector has the IR tests all as above 200M ohm, thats about 300 circuits and not one below 200 (in a 30 year old factory).
also he's only done phase-earth (has others as LIM) tests but i no for a fact he never turned any power off, made up surelly or is there some other way he could have done it?
2, the building has 2 supply's, one 400A three phase and the other is 400A three phase. the system is TNS, however the 400A supply has no earth around the armour bringing it into the installation, niether is it glanded off correctly. the other supply is earthed through the armour as should be and this is the earth for both supply's. is it aloud to have '1' earth for both supply's???
also the earths are no bigger than 50mm, a little undersized surelly?
cheers.
cheers.
