Just had a new supply fitted to the corner of a field in my small holding, PME 100A SP Located in a small brick building. I need to get a 60 amp supply over some distance about 300 metres, for which I will need 120mm2 xlpe 90 SWA. Buried direct in ground
Anyone got any ideas what switch gear to use at either end capable of this size cable. And then to scale it down and feed a CU at the other end?
