On what basis would he say it's not 500 years old?No, because he's not that stupid.
I'll cut the edges a bit wobbly and rub some lard on instead of the tin of Ronseal.
I'm not sure what point you are making or how it explains dendrochronology.I'm using a silly example to make a serious point. Britain was once covered in wild forests, and lots of these trees were many hundreds of years old when they were harvested for timber.
Unless he is a Republican or an RWR.No, because he's not that stupid.
Tree rings effectively sample the growth conditions for each year that it was growing. You check the thicknesses against other trees from other periods, the overlaps between individual trees give a history between today and hundreds of years earlier. I understand, no need to explain further. You're explaining the easy bit but missing the point.I'm not sure what point you are making or how it explains dendrochronology.
The science can be compared to undisturbed sedimentary layers. Individual sedimentary layers for example can show what was happening on the planet during a particular time, same a tree rings. Various samples from around the earth can be matched and compared. Earlier samples can overlap with more recent samples and so on, until you form a chronological catalogue. Similar with ice core samples.
Unless there's some bark in the door (unlikely) then how does anyone know how old that particular set of rings was at the time the door was made? It may give an overestimate, especially for older times when Britain had vast numbers of very old trees in ancient woodlands.
Ahh, so what you have established is that dendrochronology is about ageing the wood itself rather than ageing a door or when B&Q made it. Well done Sherlock, give yourself a pat on the back.Obviously it's been thought of before, you're only making a fool of yourself with the silly strawman insults.
My point is that it's an estimate. So arguing about whether this door is a few years older than that door is pretty silly, as nobody really knows for sure.
The most recent ring in the entire door may be a lot older than the tree from which it was made, so the door as a whole may be much less old than all the wood it is made from.
Imagine I cut down a 500 year old tree this morning, I kiln-dry it this afternoon, then make a door out of it this evening, using the wood from the centre (oldest part) of the trunk.
If I invite a dendrochronology expert round tomorrow (just after the varnish has dried obviously), will he tell me that my door is 500 years old? That was when the centre of the tree grew, so its rings should align with other wood of the same age on their records.
Correct. They go back quite a way too.Fascinating stuff...
I don't think dendro chronologists claim to always pinpoint exact felled dates, it's usually a date range along with a best estimate, which is still useful from an archaeologist or historian point of view. When sampling, say, a roof truss, it will depend on the quality of the sample, how many rings are covered, type of wood, etc. The better the sample the better the estimate.Obviously it's been thought of before, you're only making a fool of yourself with the silly strawman insults.
