I disagree with 1/
Thermally broken means the inside section of aluminium isn't actually touching the outside section but for a plastic insert which is the 'thermal break', the thermal break stops the heat transfer to the outside
Is this an AI chatGPT response because it reads like it
some points
1. as aluminium is highly conductive to heat, it will heat up quickly in a warm room. Of course, it won't do that if the frame is thermally broken then your heat is transferred outside
