Run a new cable back to the existing lighting RCBO? Or to a seperate RCBO?
If it's the former then you may as well take your feed from wherever is easiest/most convenient on the existing lighting circuit. If you can, provide means of isolation for the outside lights by way of a double pole switch; that way if you get moisture in the fittings which in turn trips the RCBO, you can isolate them causing minimal disruption to the rest of the house.
Edit: Didn't read the bit about the existing lights on the RCBO being all outside lights. As the poster below says, it will depend on existing load and your intentions for switching.
