gcol said:It took my wife a while to grasp the concept but I think she's finally cracked
I'm not surprised.
crafty1289 said:You guys with aircon, where did you fit the "outdoor" units? Say I wanted aircon in my bedroom, I would have to fit the outdoor unit high on the back wall of the house, however, my bedroom is at the front. I cant mount it on the front of the house - it would foul the front elevation. This means a run of pipework through the loft about 3 metres and down 5 feet to the outdoor unit - more than the length of hose supplied with the units. But the condensate pipe has to go downwards . . . and the instructions with the B&Q Airforce ones state the outdoor unit must be 2 metres below the indoor unit or something.
The Airforce air con units are not as efficient as an equivalent professionally installed unit. Something like 2kw of cooling/heating for every 1kw input, compared to 3kw on a pro model.
And what about servicing, for when it all goes horribly wrong / the gas leaks out? Will the pro's work on these DIY kits?
noodlz said:My endless pool helps![]()
All the benefits of a full size pool at only 8 x 15 feet
p.s. I expect this post to be deleted for advetising![]()
paulbrown said:They seem to get advertised on this site too, :
hermes said:paulbrown said:They seem to get advertised on this site too, :
Do they? Where did you see that then? I've been after one for ages.
Mine basically has the same vent as a tumble drier. Just bang a hole through the wall and put a discreet vent cover on the outside wall - that's it.crafty1289 said:You guys with aircon, where did you fit the "outdoor" units?
i have a portable one like that. its way too noisy for my liking. I only have it on occasionally. Its only C rated in energy efficiency too.gcol said:Mine basically has the same vent as a tumble drier. Just bang a hole through the wall and put a discreet vent cover on the outside wall - that's it.crafty1289 said:You guys with aircon, where did you fit the "outdoor" units?
johnb80 said:To thos who claim aircon is wasting energy, it saves energy in wintertime when used for heating so that negates that slur!
crafty1289 said:cheers pickles, but i knew most of that already.of course the snap connectors are going to leak over time, they aren't a permenant fix, like brazing the pipes. And the flexible pipe will leak too.
The DIY units are all heat pumps, so can be used in winter, this was the main appeal of buying one for our conservatory - heating on the cheap, though i knew it wouldn't last very long tbh, its still going strong.
I fancied a ducted system for the bedrooms in our house, a 3 bed semi, then just have one outdoor compressor. All the bedrooms get very hot in summer, and the ducted system is ideal because theres no noisy condensate pump in the rooms (we have one at work, the condensate pump makes me jump. its a little green thing in a corner of some trunking with the pipes in). Would a ducted system be any cheaper than 3 seperate wall mounted units? We could have it in the bathroom as well then.
I am very impressed with those new toshiba variable compressors, that operate on 20-400Hz, i have heard one operating, it makes a cool noiseand obviously no noisy startup/shudder off. probably only for 3ph though.
me toohermes said:paulbrown said:They seem to get advertised on this site too, :
paulbrown said:noodlz said:My endless pool helps![]()
I know these pools are popular in the US and also used in the UK for training etc. Are they as good as they say or were you just joking?
They seem to get advertised on this site too, perhaps thats why you weren't modded?![]()
I think the COP on quality DC inverter models is 4 or more these days....crafty1289 said:The Airforce air con units are not as efficient as an equivalent professionally installed unit. Something like 2kw of cooling/heating for every 1kw input, compared to 3kw on a pro model.
