- Joined
- 19 Jul 2007
- Messages
- 5,949
- Reaction score
- 1,143
- Country
Feed & Expansion.
Just wiggle ball valve and check water is above outlet.
Surely, the fan will only supply as much air as can be passed through the flueways, just as on oil boilers. There is a threshold below which combustion can be affected before the fume switch cuts off the power.The Flue has nothing to do with the air supply for combustion. That is the fans purpose.
It is a FORCED DRAUGHT appliance.
A blocked flue will cause the Fume switch to operate killing the fan supply.
I agree that the fuel is the most likely cause.
