Winston is partially correct about the SatCure method of fitting plugs.
"This method can leave a bad connection when used with cheap or thin or "low-loss" cable. However, good quality cable is thicker and so is the braid. This means that the braid is tightly pressed against the claws. In addition, if the copper braid is lightly coated with silicone grease, no oxidation will occur to compromise the contact in the future."
Also, SatCure advocates soldering the braid to the brass claw if you want to be absolutely certain of a good connection for life.
VHF TV is used in Ireland - unless it has been switched off recently. VHF is still used for radio, of course.
