Customer asked me to put her TV up on the wall. She wants it as close to the wall as possible. That means that there is no space to plug it into the existing two gang socket. I suggested cutting the plug off the power flex and using a FCU with an outlet, but I have only ever seen them in single gang options.
I guess I could cut a hole for a single FCU and use the existing two gang socket as a supply but the wall is plasterboard over 18mm ply and the local CEF often don't have back boxes that can deal with walls that thick.
