Cant see any ratings for the boiler switch though it does say according to the boiler manual, so that would suggest that if the boiler uses a mains SL then the switch could use that, I'd probably call Salus just to check
Pump switching may be different, due to the overrun etcAs an alternative, could you just take two feeds off the pump output? One to the pump and one to the zone valve.
Yep that's the one
So in that case. The orange SL from pump can go direct to boiler in the Lr position to activate it once the chain is formed from thermostat calling?Cant see any ratings for the boiler switch though it does say according to the boiler manual, so that would suggest that if the boiler uses a mains SL then the switch could use that, I'd probably call Salus just to check
Yes, the chain is - perm power to grey on valves - switched power from either UFH or CH to valves brown live wire - valve opens & activates microswitch - that switched live heads out on the orange wire to the Lr on the boiler - just run both orange wires from valve to the wiring centre, then just one wire from wiring centre to the Lr on the boiler.So in that case. The orange SL from pump can go direct to boiler in the Lr position to activate it once the chain is formed from thermostat calling?
Just make sure you are confident and competent to use a circuit tester and make sure everything is checked and double checked before it all gets connected and/or switched onOk thanks. Realised now I keep confusing wiring centre with ufh control centre. Will draw again tonight and see if I make sense of it
On the last question, I'm confident enough... (Will make sure I'm comfortable on paper before getting to actual wiring) ...
And no money left to pay anyone to do this ha
Thank!
yesIs hive programmable? I.e timer option built in
What would you use instead for the UFH zones (if/when these fail). I expect I can't use single channel hives for each of those 5 ufh zones?They lose contact for fun, very unreliable, if you already have them for your UFH just leave them until they fail, I would use single channel Hives for the other zones, obviously you will need 2 apps to control everything, for the hive zones you will need a thermostat and receiver for each zone but they can share 1 hub
Do you know if the existing thermostats have air sensors or NTCs inserted into the UFH ?What would you use instead for the UFH zones (if/when these fail). I expect I can't use single channel hives for each of those 5 ufh zones?
Just the built in air sensorDo you know if the existing thermostats have air sensors or NTCs inserted into the UFH ?
Hive can have up to 6 zones (plus 1x HW, when needed) in a dwelling I read... https://community.hivehome.com/s/ar...-Heating-if-I-have-a-Multizone-heating-systemWhat would you use instead for the UFH zones (if/when these fail). I expect I can't use single channel hives for each of those 5 ufh zones?
No salus rad stat currently. Only have the salus wiring centre and sq610 for the UFH zones (wired)What model is the salus rad stat that you currently have?
