As Dan has stated, it's a serious question of the building fabric & U values etc. while the pipe spacing will produce a watt/M2 output. This is only one aspect of the whole design of the system. What is your mean water temperature for example??
Are you a hairyarsed builder wanting to install this yourself by any chance??
Hello
The roof lantern is rated at u value of 1.0 but would take that value with a pinch of salt.
The orangery itself only has one outside wall which is filled with kingspan.
Other three walls are all brick which has kingspan inside.
Water temperature is 45deg coming from existing manifold
Hello Agile,
Thanks for your reply.
I noted on the web their are 100M and 150M coils.
With the area being almost 20m2 is there any advantage to me using 150M coils ?
With respect Tony that's all well & good, but what if the OP is covering the whole floor with 25mm Oak & then putting down a shagpile carpet, we simply don't have enough information.
100 mm spacing will give about 150W per sq m with many coverings so as
most heat losses are more like 100 W per sq m then there is a little in hand for the oak and a carpet.
I was wondering what people do in an orangery? Seems like something you would expect to find at Hampton Court!
In the late 17th century, Hampton Court Palace held one of the finest botanical collections in the world. William and Mary were passionate collectors of all sorts, from porcelain and rare birds to tender exotic plants. Their plant collection included 2,000 different species, including 1,000 Orange trees (the symbol of the House of Orange dynasty).
