Why do you always churn out that crap gas pipe
Because it happens that way when the alternative requires extensive work inside the house. A family in this village have a similar external gas run.
Why not show an unvented system shoe horned into some ridiculous small place ..much more common.Because it happens that way when the alternative requires extensive work inside the house. A family in this village have a similar external gas run.
Hello all,
I’ve been pointed to this forum as a source for help in a question over heating / hot water systems. Apologies for the long winded post to follow!
My 4 bedroom, 2 bathroom house was built on 1999 and is currently heated by a Potterton Supreme heat only boiler and a gravity fed hot water cylinder.
A shower coil takes heat from the water in the cylinder. I use this method for my shower, mains pressure shower and gravity feed pressure to the taps in bath and basins.
Before the shower flow was poor and I was considering putting a pump in to help solve this. Afterwards the pressure was really great - though I'm spending more time in the shower now as it's much more enjoyable - just dreading my next water bill . I know that's not very scientific, but I'm really happy with my decision. I opted for a Worcester Bosch 8000 40kw.Can I ask, what was the pressure like, particularly through the showers before and did you notice an improvement when moving to the Combi?
Why do you always churn out that crap gas pipe.Why not churn out a badly installed unvented cylinder picture too,you being a sensible,level headed bod.
an open vented, because they are so much more expensive to install,
If going for combi you can't have more than 1 tap on at any given moment, so if you having a shower someone can't flush the toilet in another part of the house
sxturbo said:If going for combi you can't have more than 1 tap on at any given moment, so if you having a shower someone can't flush the toilet in another part of the house
What utter rubbish.
I understand the discussion. Was just commenting on the implication that you can only use one tap and that somebody could not flush the toilet if the shower was in use. As I said, utter rubbish.
