Vaillant 418 going a bit wild
Well, how did it go?
Hi, I showed the electrician your photograph and mentioned what you said. He said my boiler is older than yours, going by the photograph, but the problem was very similar in that a link that should not be there had been left in place. Also, the pump had been wired up in a rather unusual way. He rewired things and removed the rogue link and as far as I can see all is well: the boiler fires when it's supposed to, the temperature rises to the set temperature, then the boiler goes into anti-cycling mode for 5 minutes or so while the pumpt keeps running. It goes on doing that until the room temperature set on the room thermostat is reached. So far no wild firings.
Thanks for your help; I don't think they would have had a look at this link without your input.
