Mattle , plenty of 4xx series boilers out there not fitted on a LLH , 30c differential will not flag up an S53.
never said it would, I'm saying it is too high
simply put
If you have a deltaT greater than 20 degrees then it can only mean one thing
the minimum flowrate req is not being met
3.14 Pump specification
The pump should be fitted on the flow pipe from the
boiler
and have isolating valves each side.
A variable duty pump should be set to give a
temperature difference of no greater than 20°C
Matt
