D
Deleted member 267285
All trv pins free?
Not what i asked. You need to remove the head on a failed one, and check if the pin moves freely by pushing down on the pin.All fully open but only one rad is slightly warm, the closest one to the cylinder
I would venture a guess as low water pressure sensor, and likely an F75.What do you mean by water sensor
Has it any resistance or “floppy “
If you have HW only selected and cylinderstat calling then there should be resistance when you pull the lever over, it should then return to its original position,if CH only selected and roomstat calling there should be no resistance while pulling the lever over, is this whats happening?.Has it any resistance or “floppy “
