Out of interest is the control software stored on an EPROM that is of the removable type?
Its not and TBH, I wouldn't recommend even attempting to modify the code! I've just looked at my system PCB to identify the revision, on a sticker it says:
0020028402
0494 0340 B
Then screen printed onto the PCB is:
TM-AC1 V132_C1 0020028453 TL-AC PM-03
However, a quick google reveals the manufacturers part number is 0020036861 (not printed on my PCB) and I find a
photo of another PCB which has different components on it yet has almost identical markings
(The spark generator and another component on my PCB are white but black on that photo) The only difference in markings is one code which doesn't look like a part number more like a date or manufacturer code
("0494 0340 B" on mine, "1043 0066 G" on the photo does anyone know what it represents?)
After doing some more tests using d.33 as a reference, I was wrong, d.0 does
not have any effect on my system (other than its use of limiting max kW).
However, I can confirm it doesn't have the initial xx seconds at a higher kW either! - In summary, my 418/VRT392/VR65/VR10 will operate WITHOUT the initial high burn kW and will modulate as necessary upto the d.0 / d.77 setting.
I believe on my previous tests, the difference I heard was due to the boiler instantly modulating to the kW it needed. When d.0 was set to 18, it could modulate higher so was therefore louder and then modulated down after 20 seconds as it needed. When I set d.0 lower, obviously it could only go up to what I set it at so was quieter giving the impression that d.0 made a difference to the xx seconds kW.
