were you able, from watching his video, to answer the two question I asked?
No one can answer that question absolutely. Give it a year and there'll be enough data to give a good guess.- I have a room that one or more other people were in earlier. One or more of them might or might not have been infected with CV. If I go into the room, will I catch it?
- Without saying how big the room is, or how it is ventilated, how long will it be before it is safe?
from the video the air should be completely safe to breath after 3 hours.No one can answer that question absolutely. Give it a year and there'll be enough data to give a good guess.
Question 1: theoretically impossible to answer with yes or no. If we knew one of the people in the room was infected then it might be possible to work out if you had enough data.
Question 2: give it three days and you're going to be fine unless you start licking every square centimetre.
Read it yourself and see if you can use it to answer the following real-life questions:
As I said - possibly.- I have a room that one or more other people were in earlier. One or more of them might or might not have been infected with CV. If I go into the room, will I catch it?
Not possible to say other than until the maximum time the virus can survive which is not stated.- Without saying how big the room is, or how it is ventilated, how long will it be before it is safe?
Are you meaning the video or the article?
The volume might not be but the number is.
Ok. so if you start with twice as many, that will take an extra time period.
Then half-life is irrelevant.
so, the 72 hours is irrelevant.
I don't follow. If people have a life expectancy of 80 years then there is no half-life.
Some will last longer and some - not half - shorter.
Therefore they might all last one day - or three days (72 hours) as is being stated - and then what?
I don't think that Viral load means what people think it means.
It's a term mostly used in HIV/AiDS where the amount of the virus in your blood is higher or lower. Lower amounts of it tends to mean fewer symptoms, normally achieved thanks to medication.
If that is the technical use of the term then saying someone is exposed to a high viral load is ******. Like saying that you need to apply to your council for building control permission.
No each cell is exposed to the same statistical probability of dying within a minute or 10 days.
The half life shows us how to create a realistic model based on a sample of a statistically relevant amount and how long it took for half to die.
The people thing is a good analogy.
If life expectancy is 80 years and you have a sample of 50 and a sample of 500 will the sample of 500 take longer to die than the sample of 50?
Each person in the sample has the same risk of dying at 1 or 81. All other things being equal.
On a completely separate note there has been some criticism of the aerosol test arguing that a medical nebuliser is not a realistic equivalent to a sneeze of cough as its designed to atomise a liquid into the air.
No arguments on that part.With regard to CV, viral load means :
- high viral load ; for the sufferer, very infectious to others. But, not necessarily displaying symptoms ("super spreaders")
This bit not so much. Its probably true but I'm pretty sure it isn't 'Viral load'.- high viral load ; for the health care person, to be exposed to a high vital load, potentially very bad. The immune system needs time to fight off a pathogen; ok if the pathogens are introduced at a low and manageable level, not so if they arrive in a tsunami.
It is not. It appears to be dependent on the landing surface for one thing.No each cell is exposed to the same statistical probability of dying within a minute or 10 days.
Not really. It depends how many there are at the start (and where they land).The half life shows us how to create a realistic model based on a sample of a statistically relevant amount and how long it took for half to die.
No, it isn't. The life expectancy is the average; not a half-life.The people thing is a good analogy.
No, but it is not to do with half-life but the maximum life.If life expectancy is 80 years and you have a sample of 50 and a sample of 500 will the sample of 500 take longer to die than the sample of 50?
Yes, but when LE is 80, only so many can die young with the maximum age being what it is.Each person in the sample has the same risk of dying at 1 or 81. All other things being equal.
