D
davebgas
They start going on at me (especially the non technical managers) and i'm off...... will go back offshore if I have to
first thing you would check if you are getting an 03 vokera fault code is, is the fan running! from your original post you said he changed the fan,nothing happened,so he changes the pcb as the fan was not getting any power!!!
when they return ask engineer to clean venturi,replace silicon tubes going to air pressure switch (aps) fan is brand new pcb is brand new check and set gas pressures and check all flue connections are tight and gaskets are intact. best of luck
Pay for me to come to bonny scotland
thats the basic usage, I can elaborate onto orifice plates and commercial venturi applications if you want
explain that to my dense colleague
if BG tell you they will have to order parts and it may take days, Heatspares in Helen St, Govan will have them on the shelf, and BG use them all the time. best of luck again
give the BG repair boys a wee chance to fix your boiler but you at least have the info to challenge them on their lack of repair skills!!
