D
davebgas
APS can most certainly be an intermittient thing, afterall they are just a basic switch, think the explanation of a venturi would have been a good idea..... sorry you're having a such a rough ride with BG
WRT Linea boiler. The fan will not run if flow switch not operated. Venturi fault would only occur AFTER fan is running. I thought the fault was present on the boiler. If that is correct surely excellent flowchart back of manual would have assisted fault location and successful repair.
Tonyboy, if thermocouple is the only component you carry in your van, you must be on the road a lot just sourcing and picking up parts.
On this boiler the control knob shaft breaks. Turning the knob now has no effect i.e. the boiler does not reset.
I would call Vokera tech and have a word with them or get them out on a FP repair at £175 and give the bill to BG.
agree with tony, once this repair is fixed, bin BG, if you get 1 - 2 trouble free years out of your existing boiler you will have payed for a brand new one, only got to pay for fitting.
check prices at ultimate discount heating @ hillington
To a certain extent I agree with both of you. However as the boiler gets older the chances are that it may breakdown more often. Always difficult to know what to do for peace of mind.
I will do. However most of the cost is probably labour I should imagine. If I were to get a new boiler I would probably have to replace radiators too.
Why would you have to replace the rads?
Your heating system is a sealed sytstem so the rads should be relatively ok,are they all heating up evenly with no cold spots? Has BG mentioned that your system is dirty?
Labour cost for replacing depends on a number of things-existing gas pipe size and available waste for an HE boiler ,position in tenement if you live in one and so one-but in the main your talking about a days labour without power flushing which will add another day to the work
Also consider a wireless stat if you don't currently have a room stat fitted or a programmer in the house.
If you decide on a new boiler I'd be happy to give you a quote,contact details are in my profile.
Tony.
