Thanks MM, this is great stuff.No, no, no. You assume the floating baffle completely separates the water from the air gap above it, sealing the air in. It does not. It is a loose fit around the central hot water discharge pipe. If it has somehow stuck then water and air will pass it, but it will not reduce the expansion volume one iota. Consider, if you must, the condition where a notional item had reduced the internal expansion volume to a size that would allow the expanded hot water to approach the 8 bar relief valve setting. In that instance it is clear to see that running off hot or cold water would rapidly reduce the pressure in the tank to the level of that supplied by the inlet pressure control set. So it would be clear that the kind of malfunction you described would NOT cause the hot water to run through the cold pipework for as long as it would with a fully operational baffle. Indeed it would shorten the hot-in-cold symptom to a minimum.
Please consider both this and the kitchen tap change to be the red herring(s).
I also suggest that the mains inlets (both stopcocks) should be within 1/4 turn of being fully open. They will have no influence on your problem.
My suggestion is to modify the inlet pipework to include the extra relief valve and the non-return valve.
There is no regulation that prevents you having a second or even third tundish, if needed, so long as the vertical run below each is the minimum 300mm before any bend.
I didn't know that the baffle could be 'got around' by air and water. What on earth is it there for? It just seems to confuse the issue as without it, re-generating the air gap would always be effective and surely the system would always work as it should.
I'm with you on the PRV/NRV bit. I'm just trying to understand what has changed. Yes, I'm putting it under extra scrutiny and opening the cold tap immediately after the hot water demand is satisfied and under normal use it could have been a hot tap opened first or, as John D has said, even a toilet being flushed. I've never checked the temp in a cistern. That said, both my wife and I noticed the problem separately as soon as the kitchen tap was changed.
I will open the stopcock under the sink up to near fully open as you suggest but I don't know what other stopcock you're referring-to.
Thanks for this help.
