Softus said:I doubt it doitall, because he said he's noticed water coming the vent.
That's how I know you're an absolute berk, because when that happens the water emerges into the cistern via the cold feed, not the vent.doitall said:Mixer tap/valve passes mains water, it backs up the hot pipe into the cylinder and out the vent pipe
Softus said:That's how I know you're an absolute berk, because when that happens the water emerges into the cistern via the cold feed, not the vent.doitall said:Mixer tap/valve passes mains water, it backs up the hot pipe into the cylinder and out the vent pipe
Hm, well, let me see, how can I put this, hm. You're wrong.doitall said:The water will be pressurised by the mains and take the least line of resistance.
In the view of the fact that this is a useful illustration of the point about which you're utterly wrong, sarcastic is a particularly inadvisable thing for you to be at this juncture.The vent if you hadn't noticed is connected to the hot pipe at the top of the cylinder, the mains water will therefore bypass the cylinder and cold feed and go straight up the vent.
Will it indeed? Will it actually stop doitall? Or, by virtue of your new theory of pressure (the one that redefines the laws of physics), will it instead "take the least line of resistance", and flow from the cistern, through the DHW cylinder, and back up the vent.if the OP turns the mains water off when its overflowing he will notice it stops, prooving my point.
Teggs said:Cheers guys,
I hope I haven't caused an argument.
As it happens I've just had a new shower room fitted, I was wondering if this was related (sorry I should have mentioned it before). This consists of a shower mixer valve and also a basin mixer tap.
While I have seen water come from the vent pipe I could not necessarily say that it was enough to fill the tank to the level of the overflow.
I have noticed that the water in the cold water storage tank is warm if that helps you in any way.
Terry
It helps a lot actually - there is no doubt now.Teggs said:I have noticed that the water in the cold water storage tank is warm if that helps you in any way.
JohnD said:hey, doitall. I have a feeling I shouldn't get into one of Softus' arguments, but... you've missed out the cold supply from the cistern to the cylinder.
Because this is lower than the vent pipe, if you think of the water trying to get out of the cylinder and back to the cistern, it will have to rise less high one way than the other.
As you say, it will take the line of least resistance, and will rise up the pipe that goes less high.
Otherwise the water level in the vent pipe would be higher than the water level in the cistern... which doesn't make sense
The only reason I rubbed it in, on this occasion, was that this innocouous comment:gasmanuk said:Softus is right in my opinion but don't he just rub it in......lol
was followed by these little gems:I doubt it doitall, because he said he's noticed water coming the vent.
Thats how I know your not a plumber
Rubbish
The vent if you hadn't noticed...
You're explaining it very well actually, it's just that you're wrong.The berk said:Softus is wrong, perhaps I'm not explaining this very well icon_eek.gif
I've love to hear your theory about why the CSS has warm water in it then!The cold feed or the cylinder has nothing to do with the problem.
Quite so - I never disputed that, but it isn't coming out of the vent!Mains pressure is backing up the hot pipe as a result of a faulty fitting.
Softus said:It helps a lot actually - there is no doubt now.Teggs said:I have noticed that the water in the cold water storage tank is warm if that helps you in any way.
Mains water is passing from cold to hot supplies within a mixer valve in your house - this is likely to be a shower valve (not a kitchen or bath mixer) because of the way they work.
The test for the theory, as doitall correctly pointed out, is to shut off the cold mains to the house while the overflowing problems is happening, then verify that the overflowing has stopped.
Water, however, isn't passing from the vent. Yes it is see drawing I'll put any money on this being condensation from the heated water in the cold storage cistern. If you have a lid on it then the underside of this will also be abnormally wet.
The problem is caused by the incorrect installation of a shower valve with unbalanced supplies. Whilst the shower valve might well be faulty, too much is being asked of it, and you need to fit a pressure balancing valve to any and all showers that are being fed with unbalanced supplies.
The only other options are (a) fit an isolating valve to the shower cold supply, and turn it off after every shower, or (b) convert the whole house to pressured hot water. Maybe someone else can think of some more options.
The reason I didn't suggest check valves is that I've tried doing that before, twice, and it didn't work. Check valves are quite good at stopping syphoning at small of even vast rates, but it seems that the ones I buy couldn't stop a relatively small trickle at the difference between mains and tank pressure.doitall said:Fitting check valves on the hot taps will solve the problem, allbeit could make another.
