A
ALEC1
there is nothing wrong with them if you install them with on-off controls...a search of the forum shold tell you something though....
Are you refering to the number of "why isn't my Vaillant 4** weather compensation/control/etc working" posts?there is nothing wrong with them if you install them with on-off controls...a search of the forum shold tell you something though....
there is no research supporting zoning as being effective in saving energy. but where my clients keep records there is plenty to suggest that weather dependency saves energy over switchng boilers on and off
says who?? what are you talking about? What can the 600 do what the 400 cant exactly? They both have the same software as far as operating WC and vaillant own controls are concerned. The principle design of the 400 is about 6 yrs older than the ecotec 600/800 series.with out knowing the sales figures we cant say, the 600 series has been about longer than the 400....
well i think people have to distinguish between weather compensation and weather dependency...the former just running up and down a curve, and the latter be able to operate with no room controls... these two being offered by vaillant and viessman on the 200 and 300 series only...
I'm leaning towards having weather compensation, but I'm stuck at choice of pump.
I'd like to go for a Grundfos Alpha - low power consumption and low noise (I assume); also ability for it to adjust speed as appropriate which seems to be appropriate for maximising boiler condensation (please correct me if I am wrong)
But of course I cannot use it in intelligent/autoadjust mode because of the need for overrun when the boiler shuts down. I don't fancy on ordinary bypass as that seems inefficient and an auto-bypass would need something fancy such as an LLH & seperate pump just for this circuit (thanks, Tony, for your earlier comments on this), all of which seems over complex, costly and is simply gaining efficiency in one area by sacrificing it in another)
Which means that I'd need to choose one of the pumps fixed speeds.
Is this entirely consistent with using weather compensation, maximising condensing potential, and minimising cycling?
I'd have thought that ideally the pump speed (maybe together with everything else including boiler modulation etc), should all be controlled by a single control unit; but this doesn't appear to be possible.
(thanks, Tony, for your earlier comments on this), over complex, costly and is simply gaining efficiency in one area by sacrificing it in another
you could have zoned them as an additional dhw/heating circuit controlled via trv/pipe sensor/stat/plc etcALEC1";p="2197205 said:sometimes you need two curves... one of my clients wanted the towel rails on in summer, but of course they would not be very warm in summer....(the cylinder reheat was too short with the solar/ part L coil)
but to be fair alex I agree, if It were on the continent an extra "heating zone" such as this would be supported and much easier to deal with
Matt
I would be very surprised if you really think that.
If you do then you must be one of those who ( wrongly ) think its best to keep their heating on 24/7
Any heating is just to feed the heat loss of the building. Cutting that out for a few hours in all or just some zones is always going to save energy !
Tony
Tony
Now then tony let me get this straight if i allow the heat loss of the building to cool down for a few hours saves me energy during this time (yes i and all would agree with this) BUT that energy is all used up againto reheat the thermal envelope of my house again!!
