i know this is very different to what is being discussed but a while back I was asked to look at a problem with a 28day RSL transmission on band II, the transmitter site being in woodland on top of the North Downs and the studio was some 1/2mile down the hill. I had supplied the cable for the stereo audio (4 pair CAT 2) and as it sounded fine with the transmitter in the studio on a dummy load and crap when in situ the fualt was promptly placed on the audio cable not being screened.
I turned up and met customer in the woods, first test I made was listening to the audio directly on the input terminals with a battery powered amplifier which sounded fine, I'd already heard how bad the radio signal sounded.
Transmitter had 3 leds (power, stereo both lit & alarm not lit) and 2 volume controls, so all looking good.
Next test was measure the mains voltage which was way down, near 150V, transmitter spec ~120W 230V and contained a linear power supply.
Customer had purchased cable to do the same run from the studio. AKA 0.5mm² 3 core flex.
I checked the maximum current by shorting the supply with current range of multimeter, which was only a couple or 3amps.
The quickest fix was a generator followed by 2.5, 4 and 6mm² cables
