I hope so!Even if there is an upstream fuse, I would imagine that that puny bit of wire would melt before the fuse operated, wouldn't it?
So there is ... Apologies for not noticingYes hes got a before photo
You'd think he'd have had the wit to remove the bypass wire before he left.Looks like hes tried to bypass the meter but bypassed the fuse instead for some reason.
I suppose it would if there were seals on the cover.Seen it quite a lot. I dunno whether it adds another layer of tamper-proofing...
As discussed, I suspect it was 'bypassing' a blown fuse - so had he removed it, the place would have been without any electricity, which would have resulted in some questionsYou'd think he'd have had the wit to remove the bypass wire before he left.
If the 100 amp fuse had blown he must have reduced the load a fair bit if that wire carried it.As discussed, I suspect it was 'bypassing' a blown fuse - so had he removed it, the place would have been without any electricity, which would have resulted in some questions![]()
Indeed. A not uncommon reason for cutout fuses blowing is 'injudicious live fiddling' which results in a (very brief') L-N or L-E 'short circuit' which does not persist.If the 100 amp fuse had blown he must have reduced the load a fair bit if that wire carried it.
A good question - but the answer could be that such would involve breaking seals - something which the perpetrator seems to have already tried to avoid doing!Why not just move one of the other fuses over
Dont mind bodging a wire in and ripping the cover off thoughA good question - but the answer could be that such would involve breaking seals - something which the perpetrator seems to have already tried to avoid doing!
Apparently OK if the seal on the fuse holder remains intact (I think it is?)Dont mind bodging a wire in and ripping the cover off though![]()
That did cross my mind too!Maybe took the cannabis growing equipment out?
