Ask any solicitor to take a similar case on a no win no fee basis and see what they say.I'm not so sure that is 100% accurate in todays litigative status involving H&S and Duty of Care.
No.
This is an open forum where anyone can post.
Anyone taking advice from here do so at their own risk.
There could be no legal implication whatsoever otherwise 99% of internet fora would shut down.
Interesting debate, I was told many years ago, if a normal person tells a buyer when selling a car, it's OK, and it turns out it was not, and the fault would not be apparent to most people, that's OK. But if one is a motor mechanic one could be found liable.I'm not so sure that is 100% accurate in todays litigative status involving H&S and Duty of Care.
Basically this is the case of someone deliberately giving wrong/dangerous advice.There are limits. Specifically, it would be unwise to post "advice" on a safety-critical matter that you know to be false:
Online Safety Act 2023:
179False communications offence
(1)A person commits an offence if—
(a)the person sends a message (see section 182),
(b)the message conveys information that the person knows to be false,
(c)at the time of sending it, the person intended the message, or the information in it, to cause non-trivial psychological or physical harm to a likely audience, and
(d)the person has no reasonable excuse for sending the message.
Not least because proving this bit:Instead, a diyer giving an opinion or advice on an open forum would not satisfy the conditions of the act and won't be committing an offence.
I'm sure that 'If I stated on this or any other forum to go grab those 2 wires and touch them together' and the person did that resulting in very serious injuries, such as blindnes, first degree burns, the injuries caused by being thrown across the room etc, starting the fire which kills his wife and baby and putting a terrace of houses in risk of collapse etc, that there would soon be a Police investigation. After that H&S may be forced into action. My credentials and work experiences (Including 2000A 3 phase supplies, extensive control systems running 75KW pumps or fans in massive plant rooms, installing 11KV substations etc) would soon be discovered. I imagine my feet would not touch the ground (Mettaforrickally).Not least because proving this bit:Instead, a diyer giving an opinion or advice on an open forum would not satisfy the conditions of the act and won't be committing an offence.
is a bit of a hurdle!the person intended the message, or the information in it, to cause non-trivial psychological or physical harm to a likely audience
This site seems to be on US servers.
If so, it is protected by Section 230. That legislation allows sites to argue that they are not (directly) responsible for content posted by users.
I am not a lawyer. My (lay) understanding is that if someone wanted to prosecute any one for posting on this site, they would need to apply to the US courts
Difference being that you know that it would be dangerous, having the experience and qualifications.I'm sure that 'If I stated on this or any other forum to go grab those 2 wires and touch them together' and the person did that resulting in very serious injuries, such as blindnes, first degree burns, the injuries caused by being thrown across the room etc, starting the fire which kills his wife and baby and putting a terrace of houses in risk of collapse etc, that there would soon be a Police investigation. After that H&S may be forced into action. My credentials and work experiences (Including 2000A 3 phase supplies, extensive control systems running 75KW pumps or fans in massive plant rooms, installing 11KV substations etc) would soon be discovered. I imagine my feet would not touch the ground (Mettaforrickally).
So getting back to this specific thread 'If I advised OPto grab hold of that link wire and yank it out(deliberately struck through to emphasise I have not and did not and would not offer that advice) and the top of the wire slipped from the fuse but the bottom stuck fast and action resulted in the the the end of the wire coming round and touching the bare earth/neutral wire and the resulting arc flash, bang, wallop gave him first degree burns, cooked his eyes and the molten end of the wire burnt into his hand and trapped between bone joints and prevented releasing it while still stuck in the live side of the fuse, shall I go on?
I'm sure that there would soon be a Police investigation. After that H&S may be forced into action. My credentials and work experiences (Including 2000A 3 phase supplies, extensive control systems running 75KW pumps or fans in massive plant rooms, installing 11KV substations etc) would soon be discovered. I imagine my feet would not touch the ground (Mettaforrickally).
I was about to write something very similar. I'm no lawyer, but I'm not so sure that the law would necessarily be all thst interested in where/how advice had been given, and how 'publicly' it had been given, if it had resulted in harm, damage or death.I'm not so sure that is 100% accurate in todays litigative status involving H&S and Duty of Care.
The only problem with that John is that the bad advice might have been given and acted on before anyone had chance to challenge it.I was about to write something very similar. I'm no lawyer, but I'm not so sure that the law would necessarily be all thst interested in where/how advice had been given, and how 'publicly' it had been given, if it had resulted in harm, damage or death.
However, as I recently wrote, one of the saving graces of forums such as this is that there are sufficient knowledgeable participants that any advice which was incorrect, dangerous or even just ';questionable' would not go uncorrected or unchallenged.
That is a problem, and I have sometimes been surprised that no one has added to what I have said, and I am dyslexic, so I can easily write something which is misunderstood. And so easy to use a double negative, or phrase which is misunderstood, like extra low voltage or low voltage, there was a post about a dimmer switch where the instructions referred to high voltage, I am sure that was a mistake, I am sure the unit was only for a limited range of low voltage.The only problem with that John is that the bad advice might have been given and acted on before anyone had chance to challenge it.
That is, of course, a possibility but, at least in this forum, the corrections/challenges nearly always appear pretty rapidly.The only problem with that John is that the bad advice might have been given and acted on before anyone had chance to challenge it.
The Online Safety Act excerpt that I posted is not related to the operators of the site. It makes it an offence for a user of the site to post something that is intended to cause harm.
