So im looking to wire in a microwave oven and a actual oven as well. im going to put eaach of these on their own circuit breaker for ease of seperation and isolation incase of any problems.
They are both rated at 16amps which is really low i thought but i have checked and its correct if anyone wants to double check my results the oven im looking to install is a Electrolux model no. EOC5651CAX 3.5kw which works out too 15amps
The distance they will be from the main fuse box will be around 5 meters in a straight line. roughly about 7 meters given corners etc its a fairly large kitchen.
I will be having a new fuse box fitted with MCBs and RCDs installed with plenty of capacity.
Id just like to know what size cable you would reccommend for each appliance?
Iv thought about a 20amp cable but given the distance and being that some of the cable will be behind a wall i was thinking maybe do i need a 25amp cable with a 16amp MCB or 20amp MCB? or does it need to be a 25amp possibly a 32amp with a 16 or 20amp mcb. The reason im thinking a 20amp MCB is because 16 is right on the limit of what its rated at or is that whats its suggesting is the best fuse size for that unit?
Thanks in advanced.
Craig
Thanks in advanced.
Craig
