- Joined
- 31 May 2016
- Messages
- 17,030
- Reaction score
- 2,579
- Country
Can the driver disengage the brake/press the go button without these lock lights, or is it more like a car seatbelt warning light?
In a situation where a door becomes faulty, he can't just park his train and call it a day, sure there must be some procedures that he has to follow, a train should not be able to move if a door interlock or a sensor signal overrides train to proceed, therefore a driver must then phone his supervisor of the problem and then override the faulty door signal or physically go down to check and manually close the door to override interlock and then proceed to allow other trains to use the line and platform. In this case he may have simply pressed an override button without thinking that someone may have been trapped, as he may have been experiencing an intermittent door problem.Can the driver disengage the brake/press the go button without these lock lights, or is it more like a car seatbelt warning light?
Crikey Bernie, when was the last time you used a train?Yes maybe there was an error by the driver but if there was an error it was an error due to a dangerous situation created by the passenger who tried to board the train after the doors had begun to close.
shall we be a bit more subjective hereSo if by chance the same thing happened and it wasn't a say, a mad dash for the train, then who is responsible?
There could be other circumstances that lead to someone having their hand trapped and not necessarily someone trying to enter the train. The driver is at fault. End of. Knee jerk my erse. Ooer missus!
