- Joined
- 22 Nov 2024
- Messages
- 7
- Reaction score
- 1
- Country
Hello, I am pretty far along in my house reno - many thanks to all the posters here! We would like to put in a log burner, this opening is where the gas fireplace/backboiler used to be.
As shown, its rather small. It is currently 590wide and 570 tall. I think a good size would be 900 x 900.
My lintel is rather high, and not very wide so I imagine this needs replacing, or another inserted below? (considering I don't need the opening that tall). It also has a crack in the middle, but it doesn't look very wide / deep and I imagine this is OK as well as it has no where to move? At least thats what my structural eng said about the lintels above my door
There is plenty of info and videos on how to add / change a lintel - I just find it hard to understand the makeup of a chimney and am hoping some here can advise, I have posted a photo of the chimney and the inside looking up.
I am a bit confused by the ^ shape brickwork. it starts just at the vertical opening, where there is a steel plate. I assume this is ONLY holding up all the brickwork under the lintel?
I can't see that there is anything above them. when increasing the height of the opening is it safe to remove these?
This is a semi detached. So this will back onto the same chimney as the neighbour, there are 2 pots on the roof. In the bedroom above here the brickwork is a lot skinnier.
1. Whats the best approach to widen and tallen this opening? Replace lintel with longer one and do a similar metal plate to get the desired height or insert another lintel at the desired height?
2. Can I remove the ^ safely or does it need some other structure instead?
3. I'm not against hiring somone, rough cost? (I am pretty competent DIY so it couldn't be silly money)
Many thanks!
Many thanks!
