Worcester Greenstar losing pressure
Yes, I've already tried that. See about 6 posts back.
I take your point about an internal pipe leak check and will report back next week.
Have a great weekend.
Sorry ,I forgot I had asked ,and you had answered already...it's an age thing :rolleyes:
Hi Terry.
I'm now having to repressurise every 5 or 6 hours to keep my heating working.
I've just gone up some steps where the condensate drain goes into a gutter. Tapping the pipe produces about 8 or 10 drips of water.
I've pressurised the boiler to 1.8 bar, left it 10 minutes and it again produces 8 or 10 drips of water when tapped & the boiler pressure has dropped to 1.7 bar already.
The boiler is stone cold, hasn't been on for 5 hours & is still dripping (slowly) from the condensate pipe.
What do you recommend I do, please? I don't want to be cold over Christmas.
Your boilers heat exchanger is perforated ,not cheap to replace and you would need a GSR engineer to do it.
Is it still under warranty,it should be if only 2 years old ?
It was commissioned on 21 Oct 22 and serviced on 9 Feb 24. Losing pressure since winter 23 and i can get a GSR to confirm. Slightly over the service schedule, so are they going to play nice, in your experience?
Yes ,if they supplied and fitted the boiler they would be your first port of call.
The WB engineer replaced the heat exchanger, but didn’t find evidence of a leak from it. I’m not sure if the expansion vessel was replaced.
Anyway, it’s still losing pressure, although a little slower. I’ll ring them tomorrow and see what they say, after I’ve checked for leaking from the condensate pipe.
