I have a Worcester Greenstar 12 Ri conventional boiler. It’s got a blue power light in the front centre of the boiler which was always illuminated to show that the boiler had power to it but I’ve noticed that the blue light is no longer illuminated. The boiler appears to work fine and when heat is called for, the green ‘burner’ light comes on as normal. There are no other lights on the unit. The user manual states the following about the blue indicator lamp, but I’ve tried this and it made no difference.
Problem....No on/off indicator
Cause.. momentary power failure
Solution.. Switch off boiler, wait a few seconds then switch on again.
I’ve googled the problem and haven’t found any other examples of this happenning (just on combi models where the light had purposely been turned off but still illuminates temporaily when first switched on.) Mine does not illuminate at all – could it simply be the bulb has blown? Is it even a bulb or is it an LED? Or could it be a fuse? As the boiler still appears to work fine I’m reluctant to get an engineer out to take a look, but of course that blue light is also used to display errors by flashing in sequences but obviously if mine doesn’t light at all then I've lost that functionality! Any advice is appreciated.
