I have just said what I believe to be the case - which, to me, makes sense as I have to comply with BS7671 or another recognised standard.
Because of your scheme membership, you mean? That aside, there is theoretically no compulsion to comply with
any Standard, 'recognised' (by whoever) or otherwise - one can theoretically demonstrate compliance with Part P by presenting arguments 'from first principles'.
If you just choose to ignore parts of BS7671 (or other standard) because it is to difficult or merely because you can't be bothered, I fail to see why you would be concerned with any of it.
I can imagine situations in which one was "concerned" about achieving as much compliance as possible with BS7671 - but with one issue for which compliance would be 'difficult'/ whatever (or if customer was not prepared to pay for the necessary work).
Would/could you install a lighting circuit today without a cpc and just note it as "That's the only cable I had"?
You obviously 'could', and that would certainly be a 'departure' from BS7671 in terms of the everyday meaning of the word, but I think you might not find it too easy to produce a convincing explanation as to why it was compliant with Part P.
...but what, for example, about a minor modification/addition to a lighting circuit which had no CPC (the work not involving any Class I fittings or metal switches etc.). Not "running a CPC to every point in the circuit" would be a departure from the requirements of BS7671, and quite probably would not be compliant with any other "recognised Standards". I don't know about you, but I imagine that at least some electricians would probably do such work.
Surely there must be a definition of departure somewhere. It is, after all, an odd word to choose or would you enter "I left at 5.30?
The word has more than one everyday/'dictionary' meaning. As well as relating to 'departure times' etc., it can also mean "a deviation from an accepted, prescribed, or usual course of action." (in many dictionaries) - and I think it's pretty commonly used in that sense. In the absence of some different "BS7671-specific definition", I think one has to assume that the word has that usual everyday/ dictionary meaning.
Kind Regards, John
