Of course, but how far would you go with your "first principles"? Perhaps you'd use cables that comply with relevant standards, screws that comply with relevant standards to fasten accessories to a wall, etc. In practice you'd probably find it easier to refer to other standards than to provide adequate proof with no reference to standards, and you'd take up a lot less of the Court's time.
Exactly - which is why, as I've said, it makes total sense to refer to relevant standards is relation to the vast majority of issues. In terms of electrical work, that would certainly include things like cables, protective devices, accessories, enclosures etc. etc. - much of which would probably involve reference to regulations within BS7671, leaving only a tiny minority of issues to be justified, partially or completely, by arguments 'from first principles'. That seems (to me) to not only be common sense, but also a way of minimising the use of Court time.
It's not that I don't accept the approach of mixed standards; my point is that if you choose to use a standard to demonstrate your compliance with the law, then the law requires that you comply with every normative provision of that standard.
Yes,
IF one is using compliance with the standard as the
totality of one's demonstration of compliance with the law, then that's obviously got to be the case.
How that legal principle stands with respect to 'departures' from BS7671 I do not know, ....
Your statement above seems to imply that you
do know - since you've just written that failure to comply with
every normative provision of a standard (i.e. if there are any 'departures') means that it cannot be used to demonstrate compliance with the law!!
As I've said, if there are 'departures' then compliance with the rest of BS7671 cannot, alone, be used as the totality of demonstration of compliance with the law - but I believe that, in practice, it can be used as the bulk of that demonstration.
As I've also said, it would be very different if the law
required 'compliance with BS7671', but it doesn't.
... but as I've said I should be in a position to ask a QC fairly soon.
I'll be very interested to hear what (s)he says. If his/her view is different from mine, you might ask him/her about the matter of approval of medicines under the Medicines Act which I mentioned - since, as I said, it is common for approval to be on the basis that "this medicine
complies fully with the approved specification for XYZ,
other than for the fact that the (colourant/ preservative/ packaging/ whatever) is different, and the demonstration that this deviation from the specification does not affect the safety or efficacy of the product is as follows ..... ". You presumably will regard that as an 'oxymoron' but I've seen it employed, in one form or another, successfully on countless occasions.
Kind Regards, John
Looks like about time this thread was closed. On-topic replies only, please.
No insults.
Or we'll close it.
MOD
