- Joined
- 14 Feb 2004
- Messages
- 74
- Reaction score
- 0
- Country
Method one does not comply because the total load on a lighting circuit should be known. It can not be known when a BS546 is fitted. You can assume a 0.5A load, but halogen uplighters are likely to be used in such sockets.
Method two is OK because it is not a lighting circuit.
My method is safe and as it does not make a mockery of "The Plugs and Sockets etc. (Safety) Regulations 1994"
All appliances come with a BS1363 plug fitted. This law was passed because not many people can safely wire a plug. By fitting BS546 sockets you may be forcing a non competent person to wire a plug. 2A plugs are very small and tricky to wire.
Multiway adapters are hard to find for 2A plugs. They are reasonably easy to find for BS1363 plugs.
Allowing the end user to switch the table lamp, standard lamp or uplighter from a remote switch without rewiring the plug is what I would call refined.
Forcing the user to fit a 2A round pin plug is anything but refind.
I think that my method is the best way of remotely switching portable lighting.
This is just my opinion.
