If you disagree, read the original question and tell me what you think the belt speed is, with a plane moving relative to a fixed point at a speed of 1mph.
With the plane moving forward at 1 mph, the conveyor reacts by moving backwards at what ever speed it needs to, to match the rotational speed of the wheel.
The plane still moves forward, and the wheels as a UNIT will move forward at 1mph as well. The rotational speed of the wheels will depend on their diameter( large wheels spin slower than small wheels for the same distance moved. )
Assuming a take off time of about 15 to 20 seconds, the wheels would only need to survive this time for lift off.
Wheel rotational speed and aircraft speed must be considered separately.
The conveyor only reacts to wheel speed , it does not know the speed of the aircraft.
Remember its the forward thrust only of the aircraft which creates wheel speed, if the aircraft is doing 50 mph the conveyor will only match this speed, through the wheels.
