If anybody wants to be convinced of God's existence, and to show them real live evidence, that is absolutely no problem, I can show that, you will need to surrender your mind and body and then I will attach some probes on your forehead and on side temples, and run a series of programmes that will help you open your mind's secret cells that can see God, some electrical stimulus and a few hundred volts of short sharp pulses fed at precise timing can condition your brain to see God. Now this experiment is like that CERN reactor, where a giant ring is used to collide atoms to emit neutrinos, but in my experiment the brain cells are contorted using electrical stimulus and this results in local neutrinos within your brain cells to be emitted and as a result of which I predict that you should see God, any volunteers and you are most welcome to my garden shed!
I am an amateur scientist and I know it should work, I give you virtual guarantee that you would see God. And you could then tell us all about him what you saw if you could find your way back, that is entirely up to you. I believe that God is hiding somewhere in your head and this stimulus should reveal his hideout and you could confront him there and then, and hopefully you will be able to ask him why? why he created hell on earth! l
You must sign a declaration that you are volunteering of your free will, and that you desperately want to see God, and secondly get yourself insured for life, and say goodbye to your loved ones just in case things do go wrong and you don't make it back from Heaven, just like they did with space shuttle Challenger, so if should the experiment go wrong, then I hold no responsibility, in case you like God so much and decides not to come back, and all those young blond virgins waiting for you that might tempt you so much that you are most likely going to change your mind coming back!c
